2G axle mount?
JStrateger
375
6
Jul 17, 2008
New Carlisle, Ohio
When installing my drivers side axle, I noticed that I was missing the mounting bracket on the axle that holds it to the block. This:
http://i18.tinypic.com/2dkbajo.jpg
The drive shafts fit fine and I really haven't had a problem related to it but I was kind of curious if anyone knew if the FWD's had those brackets on the axles or not. Just AWD? Wrong Axle? Previous owner took it off?
I think it would help with power transfer by holding the axle still.
Will the AWD drivershaft fit on the FWD? I kind of want that bracket, every front wheel drive car I've worked on has a carrier bearing mount on the long shaft and while I've never had a problem not having it, I'd still like to have it because I think it would help with wheel hop.
EDIT:
After digging around on the innernets, I found this:
AWD Equal Length Half Shaft How To
So I guess I'm going to attempt this mod on my car while the axles are out.
Anyone have a 2G AWD drivers half shaft and intermediate shaft they want to donate or sell to me? :D I'll do a write up for the procedure and results.
