2g awd with abs wheel baring
geno414
440
4
Jan 13, 2011
Milwaukee, Wisconsin
Hi i have been looking for a new wheel baring for my 1995 awd dsm with abs abs advanced auto said that the non abs one will work in my car but i kinda want to keep my abs i was looking for the hole set up so if any one could help me point me in the right spot or any info on if it will fit because i can not drive my car any more because of this.
This is all you should need. For the record, it is the other way around if you do not have ABS and you get an ABS part it will work just fine.
Removed Link.
More information, sorry.
Rear Hub Assembly is what I gave, not the front. My Bad. :ohdamn:
If I'm not mistaken the abs sensor relays information off of the axle, not the hub.
You should be fine with any 95-99 year wheel hub being it ABS or not. Just make sure you anti-seize the bolts,
and where the hub and spindle meet real good when you install it and torque them down to spec, double checking them after a couple rides.
If you want the best deal then go to ebay, you can find sellers with good sales history that have those
wheel hubs at GREAT prices and ship pretty fast. Just like this guy, $43.78 for TWO brand new hubs... And free shipping... :hellyeah:
2 NEW PREMIUM FRONT WHEEL HUB BEARING ASSEMBLY UNITS PAIR/SET FOR LEFT AND RIGHT | eBay
Or, if you need it right away and want to get it from your local advance auto store, here's a little trick to save you some cash...
Order Online! Theres TONS of coupons for advanced auto on almost any orders starting around $20 and up and they are always great deals.
I ended up getting over 35% off my last two orders from them saving myself a good $50.
And the best thing about it is you can pick up your order within the hour usually.
I checked on their site and it looks like the cheapest hub advanced is offering is the Driveworks wheel hub assembly for $74.99 plus tax.
Buy Driveworks Wheel Hub Assembly NT513157 at Advance Auto Parts
If you go advanced, the best option for you right now is this.. There is a coupon for $30 off $75 or more at advanced that is still active now.
Make two separate orders online both for the same wheel hub and use the coupon on both. You will have to add ONE more item on EACH of your purchases to get the total over $75,
so throw in something cheap like shop towels or some wheel/tire spray they have on sale, etc...
Your total should come out to about $77.00 Minus the $30 coupon = $47 plus tax .. ~ $50.00 each order for two hubs and some cleaner/shop parts.
So either you can have it right away for about $100.00 from advanced auto
or
You can get it on ebay for less than half as much but just have to wait a little longer...
The choice is yours, but I think that makes it a little easier to comprehend and decide which option is best for you..
Just take your time, get it fixed, and keep Boostin On!..:thumb:
BTW: That coupon code is from RetailMeNot.com: BIG30 $35 OFF $75
They also have a lot of other codes as well.
I wouldn't reccomend the one from oreily's, I just got one last week and two of the threads stripped at less than 80 ft/lbs. I ended up getting one from Napa.
Wow guys thanks for the great advice I will prob order the one off eBay for cheaper but thank you so much really I hope that fixes my problem with my wheels clucking and moving left and right with out moving the steering wheel thank you !
Be careful if you order them off ebay, I've made several "buy it now" purchases for the same part you need and weeks later they will contact me saying they are out of stock and have to refund my money. Try to contact them first so you don't waste a bunch of time like I have.
Alright that's what I will do thanks and I hope not ill look at my ball joint two to ne safe but I work 2nd shift welding so it's hard to get time to work on my car .
  • Wanted 6 bolt NT water pipe
    • chrisman287
