2g awd high flow e85 fuel system design
So, ended up having to do this myself. If you want to go -8an all the way to the rail you will need to drill out the bulkhead 9/16 the length of the fuel pump outlet (use the pump to measure). Then cram the pump with oring into the bulkhead like the factory setup and bam done. Pressure tested to 80psi no leaks.
Once everything is installed I will take pictures.
Sneak preview
