2G AWD Chassis bracing ???
2ndgsx
Jan 24, 2005
Chino, California
Any options for chassis bracing on a 2G AWD Eclipse or does it even need it ? I already have the shock tower bars, RM Racing rear sway bar and a bar up by the rear hatch but would like the under bracing if it's out there. I do ALOT of canyon carving .
First off, thicker swaybars have the opposite effect as chassis bracing; in fact, they make torsional bracing more important.
There is no OTS solution to the torsional weakness of a 2G (which is especially bad if you have a sunroof). The only option is a cage.
- Jtoby
  • Wanted 6 bolt NT water pipe
    • chrisman287
