2g Automatic Trans Cooler Inlet and Outlet Threads
Speedsmith
31
9
Jul 1, 2010
Gregory, Michigan
I'm not a fan of switching to stainless AN for looks but the factory automatic trans cooler hard and rubber lines take up alot of space better used for larger turbos and dumps. I wanted to replace mine and the factory hose nipples threaded into the block are 12mm X 1.25, the thread bore is also tapered for an o-ring. I found -6AN to the 12 X 1.25 with o-ring at Summit
Earl s Performance 949091ERL - Earl's Performance AN to Metric Swivel Adapter Fittings
Didn't need the swivel as it adds to the price but it's the only place I found them.
Don't forget you must use an o-ring!
Received my Earl's fittings today and they came with an o-ring that was bonded to a washer. This isn't what they pictured on their web site. BUT the o-rings off the origional factor nipples were in good shape so I transfered them over.
