2G alternator relay location HELP!
klipschaudio
103
Dec 27, 2007
tacoma, Washington
Hello,
Here is my dilemma, I burned up my alternator and my alternator relay, but I do not know the location of this wonderful relay. If someone could please point it out it would be greatly appreciated, you can also see a schematic diagram of it below. This is on a 2g eclipse. Thanks
Hello,
umm in your fuse boxes themselves there are gonne be black or like grey colored boxes. Ok one of them is gonna be a relay for the alternator. I am not sure which fuse box it is in or which relay it is exactly,but one of them will be that relay.
Sorry I can't be of more assistance to you.
Ok maybe i can be i have printed out in front of me the wiring diagrahm for a GSX's alternator. I think that the alt relay has 4 contacts in it. It might be A-07X, and its dark or id go outside and find the relay I have a 1G but I bet the relay is the same
try that and post back
Ya the relay is on there, between 4 and 2 but there is no indication of the alt relays number. On mine all it says is A-07X and it has a little picture and it has 4 points on it. One is gonna be ground, power, one is a diode, and the other one I didn't know what that one means. I can also tell you that you have a wye wound stator inside ## alternator, and its a B type circuit.
post if you need more assistance.
Thanks for the replies, my alternator magically started charging again, so problem solved. As far as there being a relay for alternator in the fuse box under the hood, it is not there, there are fan relays and nothing more, and fuses for alt, abs, etc..
