420A 2G 420a Left Turn Signal Stays On All The Time - Can't Signal Right or Turn Off Left
bo0st
835
24
Jan 26, 2010
Phoenix, Arizona
So I was driving home today and I had to make a left turn, after I made that left turn I went to turn off my left turn signal but it wouldn't turn off.
I tried turning on the right turn signal, but that one wouldn't come on.
I posted a YouTube video here:
I just start the car, and the left turn signal stays on no matter what.
Any help would be greatly appreciated!
Thanks in advance.
It's flashing faster than it should, maybe a wire shorted somewhere? Will need to prod around the wiring and do some testing to find where the problem lies.
Thanks for the quick replies!
Yes I noticed that it's flashing quicker than normal.
When I turn on the hazard lights though, they both work properly.
Where do you recommend I start checking the wiring at?
Could be a bad flasher or bulb/wire shorting. So is the lever physically stuck on left turn?
No it's not physically stuck, I can turn it left, center, right. It's just that the left flasher keeps flashing.
UPDATE: If I turn on the hazard lights, they both flash properly (and in the correct speed)
Could be the switch itself for the turn signal. Could try another one maybe or just check the wiring and see if you can see any visual issues.
Check the flasher it's probably stuck. There is a seperate flasher for the turn signals and hazards. I think they are the same part so you could swap them and see if it changes anything.
Thanks for the quick reply.
How would I go about checking the flasher? It seems to move from left to right just fine. Sorry if this sounds like a stupid question.
I really appreciate all the help guys.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
