Street Build 1995 Mitsubishi Eclipse GSX
Ownership Status
Currently Own
Turbo Type
16g
Build Type
  1. Street
- Evo 3 swapped engine (built block)
- Evo 3/RVR Intake manifold (1g throttle body)
- Evo 3 header manifold
- Evo 1 16g (49178-01470)
- Apexi down pipe/ cat back (3 inch)
- CAS rewire
- OEM Fuel pump (rewired)
- VRSF FMIC, CX J-pipe, 1g BOV,
- Mishimoto two row aluminum radiator
- Mishimoto 62 F thermostate
Mods-Engine
- JDM Evo 3 Swap
- Evo 3 head cylinder (Evo 9 valve springs and retainers, Viton valve seals
- Revised 3mm Lifters
- K stamped Camshafts
- ARP Head studs and MLS head gasket
- Evo 9 pistons stamped E9k1
Mods-Drivetrain
- ACT 2100 Clutch (with OEM flywheel)
- LSD differential
- Red Line transmission/ shock proof gear oil
- BC Racing coilovers
- Energy suspension bushings
- non-brand slotted /drilled rotors
Parts Wishlist
- 255 FP (with fuel lab AFPR)
- DSM LINK
- Injectors
- functional catch cans ( upgrade PVC system)
Background
Bought it in 2014 non-running/ incomplete from the junk before the title was switched over and scrapped, I swapped in a new motor, bought used interior/exterior pieces and engine components ect. slowly putting this vehicle back together in to make it semi-roadworthy. this is no where near complete but someday it will.
  • Like
Reactions: Shooty
ROGUE DSM
Rating
5.00 star(s) 3 ratings
More in 2G DSM
Share this Vehicle
