2g 420a can't seem to find problem. "please help"
2g2nur
Aug 29, 2009
Detroit, Michigan
I just got a 95 eclipse gs w/ stock 420. The car ran before, but now it won't start. The engine cranks and fuel pump turns on, but there's no spark and no gas from the injectors.
The CAS, CPS, ECU, and Coil pack have all been replaced but still no change. I've read through lots of forums but cant seem to find the problem. I was orginally a honda guy so I don"t know much about DSMs. Any info is valuable so please send suggestions:confused:
Since you say theres no gas nad no spark, it's probably ECU related. Check your ECU fuse, and if you have one available, try a different ECU.
i checked and the injectors work, but i just noticed that when i put the key in the on position all of the the warning lights work except the check engine light. do you think this could be an ecu problem?:hmm:
Yes I would seance your CEL dosen't come on . But I would start looking at fuses first.
def check your fuses. if you have a blown main engine fuse, i would recommend tracing the engine wire harness in the engine bay area. I've seen this happen 2 times where the egr tube melted the main power wire where they came in contact.
