General 2g 1997-99 Pin for Knock Sensor on ecu?
chanley talon
773
14
Nov 10, 2005
Spencer, Indiana
Can anyone tell me where to locate the pin on the ecu for the knock sensor on a 2g dsm. I am super frustrated.
I keep seeing 95-96 on pin 78. What about 97-99? Does it work different?
I am running into an issue where I keep getting three codes. Knock sensor, egr, and o2bank one. The knock sensor is my biggest concern. I have replaced it with two known working ones and the fault code comes right back. I tested the volts on pin 78 and I had.
. 01 of a volt. I think I should see. 04-5? Can anyone help me?
Yes, they do, what ecu are you using? if its a 98-99 they rarely go bad, the others have capacitors that leak.
Its the same for all years.
the dotted lines on the diagram mean that the wire is shielded.
It looks like:
