2g 14B conversion
Nope, you definately need the j-pipe. Unless they are complete idots and had TRE flip the compressor housing, weld on a 90 degree elbow, make and weld on a new wastegate actuator bolt hole and spent around $200 on that setup....but I know TRE does do that.....but on a 14B? Please.
QOute from him and pic.
"This kit will bolt directly on to a 2G car. As you can see in the pic the
top unit is the 14B and the bottom is the stock T25 and you'll also notice
that this unit will line up perfectly with the stock intercooler pipes and
the minor mods on the down pipe. "
Someone bent the wastegate rod all to hell. The turbine housing is not original, we would reposition the wastegate arm and TIG weld it on so it would work correctly. Other than that the turbo bolts right on without any problems and it'll look stock enough to take the car into the dealer without worry of them noticing the turbo. I sold a couple hundred big 16g's with this mod to the 2G owners when I did turbos. They seemed to like it.
You will have to put another wastegate actuator on there because the one in the photo is FUBAR'D.
Also you will need to grind the weld off where the wastegate arm attaches to the shaft and reposition it. Keep the arm/rod close to 90* so it'll hold boost properly without any funky boost BS.
Take care of those 2 things and it'll work fine.
[email protected]
