289 dergee engine coolent temp
gotgrip666
262
Mar 29, 2005
middletown, New York
i didn a comlete isntall in my car, added a hug of 100% antifreez in its and for some reasone the temp kept rising with the fans on, so i cecked the resivor cap and the water neck looked dry, so i adden like another half of coolent and it still got hot the other day, the headgasket is good, im thinking maybe bad thermostat? it would be located at the motor side of the lower radiator hose correct?
Try running 50/50 antifreeze and water. If you still have problems try 70/20/10 water to antifreeze to water wetter.
If 50/50 doesn't do it for you, go about diagnosing the problem instead of trying to "fix" it with water wetter. Some people say they have good luck with water wetter, others (like myself) noticed absolutely no change while running it.
pull the intake and check your turbo for shaft play etc, if you are on a coolant cooled turbo (factory or 16g etc). If so and you really reached those temps, first your lucky your engine is fine, and second make sure the turbo is not damaged.
Now you got me concern,, what is the ideal temperature then?
190ish area.
Enter ECU Learn Mode :: 170F (77C)
Enter fuel trim learn mode :: 180F (2G), 190F (1G)
Pull 1 degree timing :: 206F (97C)
Pull 2 degree timing :: 224F (107C)
Enter Open Loop Mode :: 228F (109C)
Default Coolant CEL :: 235F (113C)
A/C Override :: 240F (115C)
2G fan operation:
At speeds < 45 mph with a/c off, main fan ON @ 210, OFF @ 203
Under all conditions main fan and a/c fan ON @ 224, OFF @ 217
2G intake air temp (IAT) ignition advance adjustment:
185F = -3°
132F = -2°
100F = -1°
73F = 0
48F = 0
20F = -1°
-23F = -2°
1G intake air temp ignition advance adjustment:
185F = -3°
132F = -1°
100F = 0
73F = 0
48F = 0
20F = -1°
-23F = -2°
i have the scm61 oil cooled the car runs i drove it around all day i just have a massive leak somewhere im thinking from the pcv valve
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
