27 psi on a 3065 ... take a look
Staytuned
1,587
27
Jan 31, 2004
Kingston, ON, Canada
Here is a pair of 27 psi logs after a cam swap and CDI install.
280's to FP 2X's and an ARC -2 CDI with a plug gap of .030".
Looks lean because of suspected downpipe exhaust leaks around flange and flex section.
Very Nice looking logs Steve.
I think your right on the edge of what the stock MAS can read... Time for a MAP Sensor :thumb:
Could you post a similar log with the 280's?
Here is one done last year a little later in the year. HP props were changed this year to more closely resemble Mustang dyno numbers for my setup.
