225/45/17 victoracers on 9" rims?
I have 215/45 17 on an 8" wide wheel and the wheel is definitely wider than the tire. Next set will be bigger. It shouldn't hurt handling too much--it's better to go narrow tire on wide wheel than the other way around. I'd give it a shot, see how it looks and drives. You can always take them off it is just isn't working for you.
I think the concern here is that, with the grip of V700s, he could pop the bead seal mid-corner, which would really suck. I'm assuming the question is being asked because the poster has these wheels and tires in hand (or can get a good deal on them). Personally, I wouldn't do it. I'd sell the 225s and get 245/40/17s (or do the DG thing and get 275/40/17s if you have the power to launch with tires this big). But, then again, I'm a wimp. YTMV (your testosterone may vary)
- Jtoby
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
