20g And Turbonetics Manifold, Pain On The
nestamon99
41
May 10, 2004
Sunriver, Oregon
Finally after 3 days and who knows how many hours, I got my brand new turbonetics manifold on.
The problems I encountered were damaged threads on the head where the studs go and 20g turbo hitting block. I had to helicoil 5 out of 9 holes on the head due to overtightening by previous owner or cross threading.
Here's what I had to use to make this work. I am only posting to help others who are probably wondering how hard it would be to installed this manifold on a 20g HRC turbo on a 90 talon tsi awd. I had to use the adapter/shim/spacer plate supplied in the kit from HRC, you can buy this seperately. I used two exhaust gaskets, one between the head and shim plate, and one between shim plate and manifold. I also had to use the longer studs provided in the kit or you can probably get away by using 8x1.25x50mm bolts. I tried the bolts to see if it work and they did. Only thing is I don't know if their will be any reliability issues using the bolts instead of studs.
Anyway, turbo use to come alive around 4000-4200 pms, now it hits by 3800 rpms. I used the stock manifold for a while but it just kept getting worse. I had some pretty nasty cracks. Bottomline, there's a huge difference with the new manifold. Once you go turbo, you never go back. It's awesome!!!!
Did you take the time to port our your turbonetics manifold by any chance? The casting is not that great and huge improvements can be made with a few hours and a die grinder. I took a lot of material out of my collector and each runner and re-shaped the ports quite a bit.
I just wasn't happy with the fit when I originally looked at it, maybe it's better now?
Yep, I took the time to port match to gasket. I took a carbide bit to grind, then a sand stone to even out surface, followed by 120 grit roll to produce a mirror surface. I didn't really port the runners that much, I just made them smooth.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
