2 quick FMIC mounting questions
mach1one
232
Nov 30, 2003
A B., Alabama
1)I saw on an FMIC install page that to free up some room, the guy did away w/ the cooer part of the p/s lines by bypassing it. Then he cut the lower portion of the hood latch away.
http://www.dsmtalk.com/forums/images/articles/FMIC/condensor.jpg
I wanted to double check and see if the cooler is entirely necessary. I'm trying to get the thing mounted today.
2)I bought a bigger turbo outlet, but it doesn't come w/ a nipple for the boost controller. Should I have one welded in or where is another good place to tap into it?
You can just tap into the bov vacuum hose with a T connector
