2.3l stroker kit?
well i will just stick to the 2.0. :)
well will anything happen to the old crank with 15-20psi?
and what compression would you pick 8:3:1 or 9:1?
I believe theres no difference in the Turbo and N/T Cranks but lemme check real quick just in case..
Id personally run lower compression for higher boost, but if 20psi is the most you wanna see then 9:1 is ok
2.3's are the hotness... i can tell you right now that the kit from ebay is not good for 1000hp...
Whoa Whoa... who said anything about 1000hp ROFL
Is your crank damaged?
2.0 or 2.3 ROFL
Pros
More displacement, faster spool, better low end torque,
Cons
7500-8k Rev limit, more prone to damage bearings,
You know that the stroker motor still flows 10% more air at both motors' limiting rpms based on tensile stress to the rod bolts. If the safe limit for the stock rod bolts for the 4g63 is 8K then that same tensile force on the g4cs (2.4) rod bolts is at 7.4K. The 2.4 is moving 8880L/min and the 4g63 is moving 8000L/min.
Take your crank to a machine shop and have them check it... minimum they will polish it, if it requires to get cut, then i would get a new one...
If everything checks out ok, i would suggest getting the rotary assembly balanced :sneaky:
Turbo and non turbo cranks are the same in a 4G63. In a FWD I would shy away from the 2.3, you will have nothing but wheel spin. Stick with a 2.0 and go with the 9:1 compression.
Oliver
[email protected]
Oliver
[email protected]
normally i would agree with this, but at his boost level goals i doubt its nothing some good old Mickeys or any drag radial cant fix :cool:...
