2.3L stoker or 2.4L??
90gst
66
Apr 27, 2005
Naperville, Illinois
Ok I placed a post about 3 days ago...I found out I need pistons and have the block clearanced out to make it a 2.3L stroker...I've been seeing alot of posts about a 2.4L out of early sonatas and galants....If they are SOHC is it possible to just bolt on the 2.0 head on there? how would you go about doing it and what are your opinions on it...I'm planing to built my engine and then find a car to put it on...I have a 90 gst but its useless to try and put a built engine on a fwd...I'm going for a 6/4 combo with a racing tranny and clutch...I want to run 11's without an EMS...maybe a maft setup or 2g mas if possible, I want to keep it as basic as possible except for an S-afc.
To keep it as simple as possible, you don't need a 2.3 or 2.4 to run 11's.
My advice to you is build a 2.0. Cheap, and has proven itself over and over again.
Also, if you want info on this, SEARCH!! 10 sec of searching yeilded me these results.
http://www.dsmtuners.com/forums/showthread.php?t=209403&highlight=G4CS
http://www.dsmtuners.com/forums/showthread.php?t=100677&highlight=G4CS
http://www.dsmtuners.com/forums/showthread.php?t=208730&highlight=G4CS
http://www.dsmtuners.com/forums/showthread.php?t=203814&highlight=G4CS
