1st gen mods??
dsmfocker
Sep 11, 2006
colgate, Wisconsin
ok so heres the deal i bought my fist dsm :D for only a 1k only bad part fwd clean as heck and me and my dad just put the 2 new timing belts on it, runs great no rust no mods, bone stock just has a K&N air filter on it... i installed the greddy profec b 2 electronic boost controller in it and it moves all right... new fmic is on the way the problem is it seems like the rpms go up real slow and ideas? well here is were you guys come in i want my car to move real hard so it can stay with my buddys in there evos... what mods can i do to help me out with still the stock internals?
what i have laying around is a aremotive fuel regulator and a hyper external fuel pump so if i needed more fuel i have it...
thanks for your time
The second belt hes talking about is probably the BS belt I hope. As stated before do the stage 1 upgrades.
the belt u have to put on before the timing belt so what ever one that is called but thanks for the help is it worth me doing alot of mods to this even when it is fwd? and i was reading do i really gain power by blocking off the vacume lines off the throtle body?
Yes, FWD is awesome, you just may need to invest in some slicks.:sneaky: Actually its all a matter of opinion. AWD rules the streets, FWD can be fun burning out sometimes and its lighter than an AWD. You will not notice any signifcant gains from removing your emissions but here is a link for it if you want to do it.
http://www.dsmtuners.com/forums/showthread.php?t=198327
Also, don't turn up your boost without an aftermarket boost gauge and fill out your vehicle profile when you get a chance.
You wont see any real gains from removing the emission lines, but it will clean the engine bay up a bit. I think its worth keeping FWD, I think AWD is only needed when you cant keep traction for 1st-3rd. AWD might rule the streets from a stop, but FWD owns the highway, and its not all about the AWD vs FWD, I have a straight stock 1G FWD, and took a GSX with exhaust and intake pipe, and filter, its about how well of a driver you are and your launching technique. Heres a link to a thread of us FWD guys going fast>>>http://www.dsmtuners.com/forums/showthread.php?t=196598
Please fill out your vehicle profile now that you have a DSM, it will help us later on if we have to trouble shoot so problems for you.
Dustin
quater mile/ launching = awd
funner burn outs, better gear ratios, lighter= fwd
funnest= rwd LOL
At least thats how I see it, but I wish my was awd to be honest because its not like
I need highway speeds anyways, I just want to have fast launching and what not.
Now, I wouldnt raise the boost yet something tells me you have very little knowledge of what your doing and just for that sole reason dont change anything until you read all the threads posted above.
Also check out www.vfaq.com for further info.
Figure out what your purpose is with the car, if your just trying to keep up with your friends evos then that would be self explanitory of what you need but if your trying to have fast quater mile / 60 ' times and etc consider lsd and think of upgrading that tranny/ clutch since its fwd. Also most ppl would tell you if you dont have link/ keydiver chip dont raise boost too much until you get a logger to see whats going on in the engine. Would do good as a next mod for you. Gone and install your other fuel upgrades you said you had laying around ( as long as were not talking about injectors ) You'll need some sort of compensation before you install bigger injectors, then Id start with the exhaust, you cant get in what you cant get out right?! So modify your exhaust to really take advantage of most of your other mods. Then Good luck with your dsm !
