1gb turbo-ed 4g63 n/t ECU Q???
GSEclipse620
128
Nov 29, 2005
Monmouth, Maine
The name pretty much explains it. I am going to turbo my n/t 4g63(1gb talon). I was wondering what i would have to do with my ECU situation. I had a couple of options i thought of,,,
1)a GS-T ecu w/ S-AFC (bigger injectors)
2)Eprom w/ dsm link
3)reprogram my ecu (could they account for bigger injectors if I told them the size?)
I know that going w/ the DSM link would give me the most ability to tune. But I'm not sure of my capability to utalize everything nor am i sure I'd need it. My goals for this engine are 400hp. What size injectors would i need for this? I believe I am going to need some more sensors to work w/ my ecu once this is all done. If somebody could throw out a list that would be awsome! Or of any other mods/additions i would need for my ecu situation. Thanks!
The N/T ecu isn't a great idea, it doesn't have the ability to monitor knock. What are your ultimate goals for the car? That will pretty much determine what ecu route to go with. If you plan on leaving it stock with low boost, just get the 1g turbo ecu and the safc.
Whoops I just say the part where you wanted 400hp. I would get dsmlink if that is your goal. It can be done with the safc but it's easier and you get more control with dsmlink.
For the GS-T ECU you'll need to wire in the knock sensor, the fuel injector resistor pack, the BCS if you don't have a MBC, and maybe need the turbo MAS and harness connector and wire in the seventh wire. Some people run with the non-turbo MAS and it works fine. I just did this swap on my 1g and I just wired it in anyways and used the turbo MAS.
Hope this answers some of your question.
Have fun on your project.
For this project I am pretty much planning a full rebuild. I believe that i am going w/ the 7 bolt stage one SBR stroker kit for the bottem end. My goal is 400. What size injectors should i use for this? Does anybody know about stand alone systems at all? Do they totally replace the ECU, or is it kind of a more complicated piggy back system? Thanks!
