97egl
- 872
- 563
- Feb 6, 2014
Brownsburg,
Indiana
Went to replace the 1st and 2nd synchros in a 1992 FWD Turbo Transmission and I found the 2nd gear synchro is wider and has some type of material on the inside face.
When I was on Jacks website to order them they listed the Large single Synchro for 90-91 and the double synchro for 93-99. I figure you could end up with either in 92 (like 6 bolt vs 7) so I assumed since it was just a single piece that I needed the Large single one. Unfortunately, when I looked closer as I was putting it together the 2nd is wider (.402" vs .321") and has material on the inner face.
Tried doing some quick research but didn't find anything. Hopefully someone has run into this before. If not I'll try to do some more research. If someone has a link to a 92 trans service manual that would be great. Really hoping this isn't an NLA part but guessing that is a good possibility.
