1G Valve/Spring Specs Needed ASAP!!
Corman12345
117
Jun 22, 2003
Laramie, Wyoming
Hey everyone,
I am just finishing rebuilding a 1g head along with port/polish, 3 angle valve job, stainless valves and i was wondering if anyone has the specs for VALVE STEM HEIGHT and INSTALLED SPRING HEIGHT so i can finish this the right way. I have looked in every manual I own and there is nothing in there about the 1g head, it lists it for the 2g. would they be the same? Would anyone have access the books that machine shops have. I have called around here and none of the machine shops have much of any specs for imports.
Thanks
Corey
I would say installed heights and pressures would be the same as 2G because when you buy aftermaket valves or springs they are the same!!
