1g tuning help log included
jcarmichael
380
May 3, 2011
Greenwood, Indiana
ok so I got ecmtuning v3 yesterday installed everything including cut clutch wire. did all the checks before starting up running 450 injectors on 37 psi regulation (or stock) have a 255 wallsboro but don't think it is effecting anything. also running stock maf. however I am still getting knock pretty bad and Ive watched a bunch of videos on ecm and waiting to get my user id there. I have adjusted my tps and I made some slight adjustments to my idle to where my idle would only be pulling .025 mg/s for some reason my v3 doesnt have combft to see where I needed to adjust my deadtime so i just made it 50 in hopes it would be close to right. heres my log I have a guy thats really familiar coming over later to help but if I can learn anything from the community I'd appreciate it alot.
heres my log just did a small portion of cruising and a short pull.
think I am getting the logging down not much I can do until i can get my coolant and intake temps down... does anyone have a good suggestion on what kind of radiator fan I should put in i have cheap ebay ones currently wanted to go to a spal but wasnt sure about which one to get as right now in the summer I am hitting like 240 when I am running my car hard which for obvious reason I am not doing that much. also need a way to get my intake temp down got a cxracing intercooler but still running like 140 and higher temps there
