knock question, log included
arson
199
Oct 7, 2002
Kennewick, Washington
i just got my cable made up and working today for my new logger. palm viix. when i saw my knock counts i was like OMG
ps at idle it says my tps is at 18.4% and isc is around 20%. maybe thats the reason for my high idle? the question is, why do i have such high knock counts?
TPS RPM KNCK
18.4% 1563 0
33.3% 1563 0
26.3% 1906 0
19.6% 2094 0
31.4% 1875 0
31.4% 1688 0
31.4% 1594 0
38.8% 1531 0
39.2% 1563 0
39.6% 1656 0
39.2% 1844 7
39.2% 2000 12
39.2% 2156 18
39.2% 2344 18
38.8% 2531 26
38.4% 2688 26
34.5% 2781 26
34.1% 2688 25
34.1% 2594 25
34.1% 2469 25
33.7% 2344 24
33.7% 2188 24
33.3% 2063 24
33.3% 1938 23
33.3% 1813 23
33.3% 1750 23
32.9% 1625 22
32.9% 1500 22
32.9% 1344 29
32.9% 1406 29
32.9% 1438 28
32.9% 1500 28
37.6% 1500 28
40.8% 1594 34
40.8% 1688 41
49.8% 1813 43
56.5% 1969 42
62.4% 2156 42
76.9% 2375 43
80.8% 2594 43
84.7% 2813 43
90.6% 3094 43
90.6% 3406 43
90.6% 3688 43
91.0% 4125 43
91.0% 4500 43
91.0% 4875 43
90.6% 5313 43
90.2% 5688 43
90.2% 6063 43
52.5% 6344 43
18.0% 5688 30
17.6% 5156 15
the grade of gas could be a low grade like 89 and 83. the amount of fuel going in the cylinder could be too lean.
40+ knock, you engine loves you :notgood:
I'm not DSM god or anything but if your getting that much knock and your stock thats just not cool fix your TPS and that should help set it around 9 - 10 but make sure its around 99 - 100 at WOT. Have you done a boost leak test??
Do another log and have your O2 reading in there along with timing.
Hell it could be phantom knock but idk again I'm not god
have fun doin the TPS its a bi*** you either have to take off the TB or remove the Fuel rail mines was shot when i got the car so i know how much of a bi*** it is
I haven't done a boost leak test, is there a vfaq or walk-through on how to make the tester?
I'll post it up later today. thanks for the info, and does anyone know where i can get an isc? parts store wants almost 300 for one.
I logged my car before and I was getting 43 counts of knock when I first got the logger. It turned out the reason was because I was running so rich. As I leaned out my afc it went away.
i have an error 11, and in the manual it says to check injectors and such, could that be the reason I am getting the knock? bad injectors aren't doing their duty right?
