1G setting of base timing while Logger connected
a73_4g67
101
Nov 8, 2002
QC, Philippines, Asia
Engine: 1G GVR-4 4g63T, 1993 Model ECU.
Hi,
I want to set and check base timing. Can I read it from a MMCd data logger while pin 12(Timing) is grounded? Can I change the base timing and read it from the MMCD data logger? I'm reading 7 degrees during idle at the logger, pin 12(Timing) not grounded.
Thanks in advance.
steve said:
No the datalogger must be disconnected when trying to set the base timing.
Grounding both the timing adjust connectors and pin 10 on the DLC cause the ECU to enter the mode for setting the base idle speed.
Steve
Got it. Thanks Steve.
