1G 1g Saturn Alternator swap wiring
kristoph
61
4
Jul 20, 2015
mississauga, ON, Canada
Hi Everyone,
I need someone to hold my hand a bit through this wiring in the saturn alternator into my 1g harness. I am just looking to extend the wires of the oem harness.
My Harness has
x 6 wires total
(x2 Whites)
(x1 blue thin wire)
(x1 yellow thin wire)
(x1 black and white, oem plug)
(x1 yellow, oem plug)
My Alt plug has
x3 wires total
Red
black
Brown
Right now I have the wiring as follows;
OEM HARNESS SATURN PLUG
black and white wire to Brown wire (F)
Yellow wire to Black wire (L)
Red wire to Unknown (S)
Can someone confirm for me if these are correctly wired up ?
Also is it possible to confirm the thin blue and yellow wire, which sensors they go to on the oil filter housing ?
Where do I wire the two thicker gauge white wires ?
Your help is greatly appreciated,
Kris
2 white wires for the Alternator output on the B+ stud terminal
1 yellow wire to the S (sense) terminal on pin 1
1 black/white wire to the L (lamp) terminal on pin 2 (warning light and how the alternator powers up)
The other two wires, thin yellow and thin blue may be the Oil pressure Switch (Yellow B-21) and the Oil Pressure Sender (Blue B-22). There is usually another wire for the Power Steering Pressure switch B-17 that is also yellow.
  • For sale Evo 8 steering wheel with dsm adapter welded on.
    Evo 8 wheel with welded adapter for dsm
    • 98TalonPandaTSI
