1G rebuild
holland
45
Sep 25, 2005
Bakersfield, California
So its time for a rebuild on my 1G but I'm not sure what compression to get. I have a T04E 50 Trim but I'm not sure if I should go with the 8.0.1 or the Wiseco 9.1 from Road Race. I do not have DSMLink as of right now but I will definitly be purchasing that. Other mods include AEM fuel rail, walbro 225, Aeromotive FPR, 850 inj....... another mod I'm thinking is 264 cams instead of the 94's I have in it now.
Any suggestions would be greatly appreciated.
Well if you go with the higher compression, you will have quicker spool, but if you go with the lower, you will be able to run a higher boost with less detonation.
I hope this helps you some, that's all I'm comfortable informing you of.
