1g power steering lines?? orr??
Siral3x
299
Mar 2, 2006
Ludington, Michigan
Ok I'm sick of DSMs having PS fluid leaks :) JK! but my ex 95 GST had it too...
OK..so I'm loosing a lot of PS fluid....after 3-4 days I don't have PS anymore. I got sick of buying fluid all the time.
After I park the car I find in the mornings fluid leaks in front of teh car right under the bumper...took a close look and the PS cooler lines are soaked and dripping??
Then I follow the lines to the bottle, and same thing, soaked and dripping at one point...then from the PS pump to the rack...right where the lines goes into the rack is leaking and gives another leak spot under the car on the driver side.
I know I need pretty much all the PS lines??just to be safe...
How hard would it be to replace them???the one that goes in the rack looks like a PIA to replace..
I'm planning to get a FMIC also sometimes soon, I hear that you gotta relocate the PS cooler lines and the oil cooler??(90 gsx) what are my options here?
thx
i would steam clean the engine compartment and determine which lines are leaking.it may just be loose clamps. a clean engine is easier to work on. there is an article in the teck guide to relocate your p/s cooler
  • Wanted 6 bolt NT water pipe
    • chrisman287
