1G pop up headlights
Siral3x
299
Mar 2, 2006
Ludington, Michigan
Ok,
I they worked fine till today.
They poped up and won't go down anymore or move...pressed the stupid button 1 mill times..won't do nothing.
What do I have to do and starts testing?
They are Up and won't go down..the lights work perfect...just won't go down again
thx
What button did you press 1 million times? Are you sure you didnt press the button on the dash that keeps your headlights up at all times?
i had this problem the other day..just out of the blue they stopped working....in my case i took a look and the linkage that goes to the headlight to the motor came off, so i had to snap it back in and then i just wd-40 every moving part so much that i could push it down by itself and back up and it worked out fine otherwise it is the switch they tend to go out after 16 years of service. hope this helps and if not just give me some more info and ill try again
