Resolved 1G Oval body plug for AC Harness
Bryan 93
99
13
Nov 5, 2013
Mentor, Ohio
Anyone know a part number of a plug to fill this hole? It is the hole where the harness for the AC comes through by the front drivers fender to the AC fuses and relays? I assume cars without AC didn't have the same harness, and had come sort of filler, but I can't find a part number anywhere, so maybe I'm wrong?
Solution
If you have a junkyard around with any 89-93 Galants in them, you may want to pay it a visit. Same location on those cars as in a DSM, I found some of these:
The part number is MB543080.
A potential alternative Subaru part is # 909410027, which I came across in the yard as well. Here’s some pictures of it - it looks a little nicer than the Mitsubishi part.
If you can take a measurement of the hole size you can probably find something to fit. I see a few that are around 2"x 3" and some that are smaller too, but it's hard to tell what size you need by looking at the picture.
It's an oddball size, 1.33" x 2.09" (34mm x 53mm), not sure what the radius of the curves are. Trouble I was having many of the body plugs just list specific applications, they don't list sizes.
Well... This is the closest I can find and I think it might work for ya.
1.31" x 2" http://www.justmopar.com/store.php?crn=252&rn=934&action=show_detail
Thanks, that might work. Other problem I have is many of the sites list the size as the size of the plug, not the actual hole. Nothings easy any more... Your link led me to:
http://www.steelerubber.com/firewall-grommet-50-0165-20
This might work as well, I can easily plug the hole in the center. But again they list the size of the plug, not the hole meant for it to fill. Maybe I will email some people and see what they think.
Good luck Bryan! :thumb:
Solution
