1G NT TB on a 2g turbo?
blcknspo0ln
DSM Wiseman
7,772
101
Jul 31, 2003
Central, New Jersey
really noob question but I need to know before i take apart anything. anyone know if you can use the 1G nonturbo throttle body on a 2g turbo mani? is there anything different? from the looks of it they are similar, except the water lines are facing the other direction.
I am sure there is a reason people use the 92'-94 1G Turbo throttle bodies vs. every other 1G throttle body, but I can't tell you why cause I don't know.
Its a good thought though, N/T 1G's are everywhere.
Someone will know for sure, and why.
gsxtacy
Yes you can. The nt throttle body has a bigger opening then the turbo one but by the throttle plate they both have the same dimensions.
replace the shaft seals befor you put it in with the ones from the turbo TB.
just what ive heard.
