1g maintenance
masa79
34
Jan 23, 2004
-, Europe
I just bought eclipse gsx 91 and car is not drived about 8 years.What i have to mantain?
Anything else with these:
Timing Belt
Balance Shaft Belt
Timing Belt Tensioner Bearing
Timing Belt Idler Bearing
Balance Shaft Tensioner Bearing
Hydraulic Tensioner Adjuster
Water Pump
What do you think if i buy underdrive pulley and balance shaft eliminator kit?How much hp i can get these?
Thanks for the help and sorry for my bad english :)
changing every single belt and all the fluids oil, trans, transfer case, rear diff, brake would be a good idea :thumb:
For the price of a Balance Belt and the Bearing you might as well get the eliminator kit instead if your not worried about the work involved. Cost is equal..or even a bit cheaper for the eliminator kit. Slowboy sells TB kits minus Balance stuff and Elimination kits.
I believe I paid $290 shipped for an OEM TB kit, Balance shaft elimination kit, and a water pump at slowboy. Just watch out don't assume just because it says Timing belt kit it actually has all the bearing and stuff you need..seems some places leave certain bearings or parts out. frustrating..also watch out for non OEM Timing Belts..I think I saw extreame selling Gators..wich I've not heard such spectacular things about.
Is there any problems if i put balance shaft eliminator kit.Driveability and what is eliminator gains?
And my car start shaking suddenly few days ago.It shaking over 40mph speeds.Somethings broken.
