1g logging cable problem
trbotaln
633
9
Sep 7, 2004
hidden hills, California
Whats up guys,
I already searched and well I just picked up a 1g gsx and the car came with a logger cable that looks home made. It has a USB connector on one side and the other side has a red wire, and a black wire with another black wire attached to it to jump something I guess. The OBD 1 connector has three pins and I have no idea which plug goes to which pin. Does anyone have a picture or something on how it connects? I will try to get a picture of what I am talking about.:confused:
Ok, locate the diagnostic plug, where the pins are, sounds like you know where it is already.
The red wire hooks into the top left corner pin on the plug.
The other 2 go on the lower right side of the plug... one in the lowest furthest right pin, and the 2nd one goes in one above that pin...so theres one pin in between, the order of the black wires should not matter.
Hey thanx a bunch man,
Damn that was fast,I tried it out and it worked perfectly. I really appreciate your help, now I can try to figure out why my car dies when I slam the throttle plate shut.:thumb:
