1g Ignition Switch Wiring colors needed
the_intimidator
41
Feb 4, 2008
Roseburg, Oregon
Does anyone happen to have the wiring diagram colors for the ignition switch on a 1G manual GSX?? and correct me if im wrong. 1 screw and the ignition switch seperates from the lock cyl and there is a plug in that pulls apart so you can replace JUST the ignition switch right?
Eric
Well i can't answer your first question yet. Maybe tomorrow i can run outside and take a look at the colors. As for the second question yes. Just one screw and that plug in and it's out. If you still need the wire colors send me a pm because i've got a memory about as good as a pop tart.
