GSLENK
- 1,416
- 55
- May 25, 2011
DC,
Maryland
I know its a green/black wire from the steering wheel... but that only works when the key is in the on position... anyone know where I can tap to use the factory horns instead or the gayiezzo siren? Will this be a low amp circuit or will I have to use a relay? thanks
I guess Ill find it and post an update. Im still trying to find the hot side of the horn circuit in the cabin, near the ign switch.
Its suposed to be a green/white wire. If I bypass it to have constant power so the horns always can work, will it power up anything else unnecessary, and drain the battery?
