InfiniteGSX
- 3,182
- 16
- Dec 10, 2002
Tijeras,
New Mexico
I'm Moding my 1g stock gauge cluster to hold aftermarket gauges. Since I'm working on a budget project, I can't just go out and buy all the gauges, so I'm doing one at a time. Starting with the boost gauge. Regular sized (56mm or what?) Gauges fit in the three center holes flawless with minor mods. All I had to do was take out the gauge from the cluster, take a knife and easily go around it in a circle a few times, taking a clean shaven layer off. Eventually the Auto Meter UltraLite fit great! What my plans are, is to replace the Water Temp, Fuel Level and Oil Pressure gauge with Boost Pressure, Fuel Pressure and oil Pressure. I was thinking of using black AutoMeter gauges for all of them, except the boost gauge, so it will stand out. Plus since I have a digital FP Gauge in black and an Ultra Lite Boost. I decided to have the boost gauge which is silver in the center. It looks great:
Eventually I'll put the Digital FP gauge inside the Fuel Level area, and the oil Pressure gauge in the water temp area. And a Auto Meter in dash tach and speedo will move in as well. I want this to look as "Modified/Stock" as possible. So Stock placement, same size speedo and tach. I'll also put up different color LED's for certain things that "NEED" to be monitored, I'll even include a very bright orange LED to shine directly at me, in the center of the 3 center gauges, for a shift light.
However like I said, this is a budget project so I can't do it all at once, gotta do it over time. So I put the boost gauge in, it fit flawless. But to install the boost source, I had to cut some of the trace/plastic off of the back. I was going to sand down the traces I cut, and replace them with soft wires with solder, including re solder some of those ?Resistors?... Which is where my question comes in, In that square area, I cut all of that. So what did I severe exactly? Does anyone know? Right now I have my dash torn apart to do some clean up on the wire harness, so I can't find out whats not working.
