how to replace 1g gauge cluster.
93EagleTalonDL
91
Oct 27, 2005
Williston, North Dakota
okay i bought some blue gauges for my instrument pannle (RPM/SPedometery etc.) and i was wondering if their is a tutorial or soemthign on the net that i could use to change them.
the gauges came with a dimmer on the switch to change from blue to green.
can anyone help me?
Do you mean as far as getting the stock gauge cluster out of there or just how to replace the faces once its out? If you don't know how to get the cluster out, there is an article in the tech section that shows how to remove the cluster. Once out of the car you need to seperate the clear front peice from the rest of the cluster assembly, and then remove the center section (the solid color peice you see around the gauges. Then remember where the needles are and pop them off. Then remove the tiny screws.
you might be able to get the gauge faces on without taking off the needles...thats what i did with mine..mine just slipped right over the stock ones...try slipping them over the needles before you take the needles off.
