1G 1g fwd rear subframe in awd
2g is not involved in this.
Yes for the most part, does the mean it uses pre existing studs?
I know a 2g isnt involved in it i was simply saying the people that swap (all though not from awd to fwd) are 2g guys
Yes it can be ddone on a 1g but you would be better off buy (assuming your situation) a new awd rearend
If your thinking you can keep awd and use fwd rearend not gonna happen they are so differant its not even funny a fwd is a solid axel all the way across and an awd is the center subfrme and aarms coming off of it for true independant suspenssion
  • Wanted 6 bolt NT water pipe
    • chrisman287
