1g fusebox connector?!!!
kwAlk23
82
Sep 9, 2006
Palm Harbor, Florida
Im in the process of trying to fireup my 1g that i swapped a 6bolt in and i'm trying to figure out what all these connectors go to. Theres one that I couldnt find a place to hook it up to, its the 4 pin connector below the MPI IGN and fan fusebox coming off of the positive harness from the starter. Also, where do the 2 throttle body connectors coming off the throttle body go?
Do you have a picture or can you take one? I just replaced my starter a week ago and i can't for the life of me think of any connector coming off the positive end of the starter. And the two connectors for the TB.. do you mean what they are or where they go to?
James :laser::talon:
The 4 pin connector from the starter harness should be plugged into the main harness around or below the battery. I cannot give you the exact location as you did a swap so it is hard to say exactly where it is at now. That connector is important to hook up as it supplies power to the solenoid to start the car. The hoses are too vague, we need a year at the minumum as there are more than one configurations for the connectors. It sounds like 1990 throttle body which has a connector that goes to the firewall for the idle speed controller and the cam angle sensor. The cam angle sensor wires just attach to the throttle body with a wire tie for support. This is all that I can see without a year for the throttle body. goodluck
