1G fogs with highbeams?
sc2_ct
151
4
Apr 2, 2004
Meriden, Connecticut
I tried searching (here, vfaq, 1000aaq) and maybe I'm just searching the wrong terms. I was wondering if there was a way to get the fog lights to stay on with the highbeams? All the info I found on my searches dealt with 2gs, but none for 1gs as far as I can tell.
You would do the same procedure as the 2G. You want to do the same thing, just remember that your locations of the parts described wont be in the exact same place.
I don't have any pictures but doing it is simple. You ground the circuit at pin 2 of the fog light relay in the fuse/relay box under the hood. It's a red/blue wire that runs to the dimmer switch. By grounding it you activate the fog light relay all the time that the headlights and fog light switch is on. The stock wiring would break the ground when you turned the highbeams on.
Steve
  • Wanted 6 bolt NT water pipe
    • chrisman287
