1g Eibach front pro alignment camber kit install ?'s
JamesRayburn
Mar 26, 2009
Washougal, Washington
Has anyone installed the eibach pro alignment kit for the front suspension?
Do the bolts replace the 2 bolts that hold the strut on to the spindle? Whats up with the washer with the little tabs on it?
Okay, figured it out :hellyeah: For anyone else interested...
The bolts replace the top bolt on the spindle. One is needed for each side, so you only need to purchase 1 kit. I ended up buying two thinking I needed one kit for each side.
I installed mine but am still wearing out inside of tires very quick, like a month and they are going flat (brand new tires) have not had it aligned but turned the bolts so that I should have had most positive camber it could give me.
That would make since. I never thought about that. Getting it aligned tuesday, took it to BIG O to get tires and also told me a ball joint it about gone so I need to look into that also.
got it aligned and could only get it withen -1.0 degree of camber... in the front with the eibach kit, used a pry bar to pry out a little and tightned bolt up and got it to -0.5 on left and kept the right side at -0.7
toe was way out on the front though and got it set at zero on both sides
I am planning to install my new eibach camber kit which i purchased few days ago from eBay. The problem now, is that it has no manual on how to properly install that. Any additional information?
