1G 1g Eclipse door moisture barrier?
RACEPAK1
40
6
Apr 4, 2016
RAMAT GAN, Europe
Any chance someone has a picture of 1g Eclipse doors with no door cards? I want to see how the OEM moisture barrier sits on the doors. Thanks a lot
I don't have a full pic, but maybe this helps? I've actually been wondering how to reaffix it where I pulled it away. Seems the black glue/sealant doesn't stick anymore and no amount of heat or brake clean revives it.
That black gooy stuff is 3M Windo-weld. It's polyurethane "rope" adhesive. The part number cooralates to the different size, width & thickness. I just bought some from Amazon to redo my 2G doors. It's nasty stuff and hard to clean (both the old dried stuff and the new), sticks to everything & anything. I've had the best luck using WD-40 as the solvent. Have fun, I know I am.
This is what Mitsubishi used & would be OEM.
