1G 1G DSM Transmission compatability
Ceezdsm99
108
17
Mar 11, 2022
California
So I have 1993 Eclipse GS 2.0 with the 4g63 N.A. 5 speed manual trans , and I’m hearing chattering coming from the passenger side axel and clutch and it might be the trans since it has 200k miles of abuse on it … here are the part numbers that I need and a picture . Anyone know what trans are compatible with this 6 bolt 4g63 ?
a60ckz ga6936
You need an N/A transmission. F5M22 is the "part number" You can get it from ANY non-turbo 91-94 DSM. The 1.8 and 2.0 N/A have the exact same transmission.
Also just FYI if you have a 93 with the original engine it's a 7 bolt engine not a 6 bolt, but the transmission are the same from 6 bolt to 7 bolt
The A60CKZ, I imagine, is the early version of the KM206-0-CKZ that was found in D09V or D09W Mitsubishi Chariots. Very similar to the 1G non-turbo transmissions, all except the speedometer gear ratio (31/36 instead of the 1G NT 29/36) and the final gear ratio (4.021 instead of the 1G NT’s 4.322)
As stated, the original 1G manual non-turbo transmission is coded F5M22. The transmissions from the 1.8L technically have different part numbers than those from the 2.0L, but they should be interchangeable if need be.
  • Wanted 6 bolt NT water pipe
    • chrisman287
