1G dsm rev issue
brandonclum
136
May 20, 2009
spokane, Washington
Ok so I cant get over 4k rpms while driving or in nuetral, that's it wont let me in any gear. Here are my main mods. 16G,FMIC,hard pipe,Gm maf w/maft v2.01,Have 43psi auto FPR (did 5 speed swap),450cc injectors and rebuilt ecm from ecmtuning, thats the main stuff I have tons more. Just as a fyi I did the usual changed fuel filter,boost leak test and leak/comp test all is well. Its almost like the car stutters at 4k I'm starting to think flat cam but with rollers how does this happen?:confused:
What was the last under the hood work did you do, befor you had this problem? I had ths same issue, and I belive mine was the ecu was leaking. And eventuly it wouldn't keep the car running, had to 2 foot the car home.
The last mod I did was the 5 speed swap the strange thing is is that it did the same thing with the auto trans. The guys @ ECMTUNING did my ecu for leaky caps and cleaned the board. Also its idle surging really bad when cold and today I drove it and while under boost it wanted to die did it once and that was it. Just a note I do have an exhaust leak at the down pipe.:mad:
ya I logged it and it says im getting somthing like 40+ counts how could this be im on stock boost at the moment. I guess it could be registering phantom knock if its bad ill change it out and see if it helps. When I bought the car and rebuilt the engine I didnt replace it cause it looked new but looks can be deceiving. I'm also going to change out all the sensors and the maf I have a 3" gm on there now with the maft.
Sounds like you've done everything in your ability to figure out the problem, how about getting a opinion from your local Mitsubishi mechanic? No one knows everything. Don't be afraid to pay $100 bucks and get the diagnosis and then perhaps you can fix it yourself.
I think I may have figured it out the closed throttle position sensor (is bad I think) I unplug it and runs fine plug it in it surges and everything. Looked everywhere that I can think of to buy a new one and cant find it. Can I run with out this plugged in?
