1g cas on a 2g
sharky559
191
Mar 6, 2010
Sanger, California
ok so i finish installing the cas. i did buy the 1g to 2g harness. but what i want to know is what alse do i have to do. someone said swap the spark plug and someone said swap the injector pins on the ecu. could someone help:confused:
I personally swapped the two wires on the ecu harness (even though its harder to do) because I knew I would eventually forget which wires went where as time went by.
