1g CAS in my 99 spyder gst
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
I'm putting a 1g CAS on my 99 gst spyder. the motor is a 7bolt but I know it
's not a 99 style
I'm stuck on the part that gets wired up to the cam angle sensor.
My 99 has the wiring for the cas on the left side of the motor. (not on the top right)
I think I got the part that gets wired up to the crank sensor correct
but what about the part that gets wired up to the cas- how come only the blue wire is used. I'm trying to go off this rre diagram. If I do it the 97-99 style do I have to swap out any injector plugs or wire anything up to the ECU?
RRE Instructions
I HAD A 1G CAS ON MY 7BOLT 2G... IT WORKED FINE AND COULD ADJUST MY TIMING TO GET THE MOST OUT OF MY TURBO...!!! alot of people do it...!!! use the search button... im pretty sure youll find it
so pretty much sense I don't have the cam angle sensor PLUG just the wires. I would just wire it up to the blue to white wires. I get the Crank sensor part I just wasn't sure about the cam angle sesor part.
Is that all I have to do? do I need to swap plugs or run a wire to the ecu??
what I'm trying to say is I don't have the cas plug. I just have the 3 wires coming off the harness.
