1g brake problems
tsi_daggie
146
Jan 2, 2005
Sibley, Iowa
i am putting new pads on the back of my 90 talon all wheel drive. i got the caliper off. and turned the piston in all the way as far as it will go. and with my new pads there is not enough room for the disc. do i need to grind a little off the pads or is there a adjustment spot that i am missing. any and all help is much appreciated
Make sure when you turned the piston back in that the two indentations are facing up and down (in relation to the caliper). The pads have a nub that sticks out on the back of them and if the piston indentations aren't vertical then the nub won't allow you to lower the caliper enough to get the lock pin through. :thumb:
