1g bov
Some think the Dodge mod is safer, plus adjustable. As far as which one holds more, I would imagine that there is only a certian limit that each one will hold due to the BOV itself, not the mod. So esentially they could hold the same amount of boost.
The DG mod by itself can hold more pressure while still maintaining a usable BOV. Dejon's BOV Leak Stop Kit, is basically the same as the DG mod, and has been tested to hold >30psi with very little leakage.
How fast can you do this mod? Can you have all the needed materials before Sat?:sneaky:
I've both the DG-modded and crushed BOV and works well :)
Faster than you can send me that flange I'd asked for last month :nono: :p
I actually have an extra DG'd BOV (uncrushed) painted black wrinkle you can tryout first. Maybe I should start a service :D :dsm:
