1g BOV adapter
There should be a clamp to undo on the intercooler pipe which you will have to loosen to take the stock blow off valve off. Then you should be able to push the end of the adapter in place of it and tighten the clamp around it. :thumb:
Ummm, there should be a clamp....you will loosen this clamp to remove your old valve then tighten the clamp once the adapter has been installed. There should be a rubber sleeve that will either stay on the base of the old valve or stay in the piping with the valve removed- you'll need this on the new adapter. I've found it's easier to install the rubber sleeve into the pipe first then install the adapter and tighten the clamp.
All-told, installation should take less than 5 minutes....much longer if you smash things with a hammer.
