1g awd/t talon slower with a t3/t4?
mitsuman_626
Mar 13, 2005
salmon arm,
Any one know why a 1g awd/t talon would be slower with a t3/t4 ar.62 at 22psi than a stock
14b with 18 psi
mods:
huge FMIC, 3" intake and exhaust, mass air translator, walboro
data logger reads both set ups are tuned well
:cry: :cry: :cry: :cry: :cry: :cry: :cry:
What injectors are you running with? Are you logging? You're probably maxing out the stock 450s. Which pump? 255 ? afpr? Sounds like your fuel system isn't keeping up with your other mods.
255 pumpand base pressure set to 65psi
had all the same mods with the 14
logs read good
my only guess is stock cams aren't doing it, what do you think????????????
The base pressure for 2g's should be set at around 44psi, do you have an afpr?
No definitely not, a lot of us are running big turbos with the stock cams, your problem is fuel related. What is the turbo's flow rate? I really don't see how stock 450s can support a turbo that size at 22psi.
FIRST OFF your problems isnt CAMS. its COMPLETLY FUEL RELATED u will need like some 650,660,700 cc injectors to run that big of a turbo, and tune the thing. IF YOU dont tune it your car will still be slower than when u had the 14b.
jeez thats some high fuel pressure WTF
At that base fuel pressure and with the pressure drops between the regulator and pump the relief valve is likely popping open at 22 psi. That 87+ psi at the pump just from base + boost not counting losses. Even the 255hp is going to have problems with that.
Steve
thanks everyone......
660's and lower base pressure helped
the 14b power still comes on sooner but when this one spools it really takes off.
just had to adjust my driving style alittle
